1GNDT13WXWK209328
1: 1: U.S. BUILT
G: G: GENERAL MOTORS
N: N: CHEV MPV
D: D: GVWR RANGE 5001-6000 BRAKE SYSTEM - HYD
T: T: SMALL CONVENTIONAL CAB 4 X 4
1: 1: 1/2 TON
3: 3: FOUR-DOOR CAB/UTILITY
W: W: ENG OPT - L35 DISPL(L) - 4.3 CYL - V6 FUEL SYS - CPI
X: Check digit
W: W: 1998 MODEL YEAR
K: K: LINDEN (T&B) NJ
Код модели кузова: CT1050
Двигатель:
Коробка передач:
Модельный год: 1998
Дата производства: 26.03.1998
122: TRIM COMBINATION LEATHER,GRAPHITE,(122)
12I: INTERIOR TRIM GRAPHITE,(12I)
1SF: PACKAGE OPTION 06 OPTION PACKAGE 06 OPTION PACKAGE 06,(1SF)
41U: EXTERIOR COLOR,PRIMARY,(41U)
6WK: COMPONENT FRT LH COMPUTER SEL SUP (6WK),SUSP(6WK)
7WK: COMPONENT FRT RH COMPUTER SEL SUP (7WK),SUSP(7WK)
A26: WINDOW,UNITED KINGDOM AND EUROPEAN GLAZING(EXPORT),EUROPEAN WDO
A31: WINDOW,ELECTRIC OPERATED,SIDE,ELEC SI WDO(A31)
A78: ADJUSTER,FRT ST BK MAN RECLINING,PASSENGER AND DRIVER,MAN RECL S
A86: MODIFICATION RESTRAINT SYSTEM, EXPORT,RES SYS,MODIFICATION(A86)(
AG1: ADJUSTER,SEAT,6-WAY POWER,DRIVER(60-40)(VAR 2),6-WAY PWR D/SEAT
AU3: LOCK,SIDE DOOR,ELECTRIC,ELEC S/D LK(AU3)
AU8: LOCK CONTROL REMOTE ENTRY, SPECIFIC FREQUENCY,REMOTE ENTRY LK CO
AX4: RESTRAINT SYSTEM,FRONT AND REAR SEAT,MANUAL(EUROPEAN),MAN RST SY
AXP: VIN IDENT POSITION, MULTI- PURPOSE VEHICLE,MULTI-PURPOSE VEHICLE
B30: CARPET,FLOOR AND WHEELHOUSE,FLR CPT(B30)
BAG: PARTS PKG EXPORT,PARTS PKG(BAG)
C25: WIPER SYSTEM,REAR WINDOW,RR WDO WPR(C25)
C3T: GVW RATING 5350 LBS,5350 GVWR(C3T)
C49: DEFOGGER,REAR WINDOW,ELECTRIC,ELEC RR WDO DEFG(C49)
C68: AIR CONDITIONER,FRONT,AUTOMATIC,ELECTRONIC CONTROLS,A/C AUTO ELE
CE4: WASHER,HEADLAMP,HIGH PRESSURE,HDLP WA(CE4)
CZ3: COUNTRY RUSSIA(EXPORT),RUSSIA(CZ3)
D07: CONSOLE,FRONT COMPARTMENT FLOOR(CUSTOM),CUSTOM F/CMPT FLR CNSL(D
D34: MIRROR,INSIDE,SUNSHADE,S/S MIR(D34)
DD8: MIRROR,INSIDE,REARVIEW,TILT,AUTOMATIC,LIGHT SENSITIVE,I/S RR VIE
DK2: MIRROR,OUTSIDE,RH & LH REMOTE CONTROL,ELECTRIC,LH DEFOG(PAINTED)
DK6: CONSOLE,ROOF,RF CNSL(DK6)
E55: GATE,END,END GATE(E55)
EVA: TEST DVT, EVAP EMISSION REQUIREMENT,EVAP EMISSIONS REQUIRED(EVA)
EXP: EXPORT - I.E.S. EXPORT I.E.S.,EXPORT-SPECIFIC MARKET AREA EQUIPM
F46: CHASSIS ALL WHEEL DRIVE,ALL WHEEL DRIVE(F46)
FK2: ARM,TORSION BAR,SPRING ADJUST,LH,TORS BAR SPR ADJ ARM(FK2)
FK3: ARM,TORSION BAR,SPRING ADJUST,RH,TORS BAR SPR ADJ ARM(FK3)
G80: AXLE,REAR,POSITRACTION,LIMITED SLIP,POSITRACTION L/SLIP R/AXL(G8
GT4: AXLE,REAR,3.73 RATIO,3.73R(GT4)
JC1: BRAKE VAC POWER, 4 WHL DISC, 5,500 LBS,BRAKE VAC PWR(JC1)
K34: CRUISE CONTROL,AUTOMATIC,ELECTRONIC,CRCONT(K34)
K60: GENERATOR,100 AMPERE,100 AMP(K60)
KA1: HEATER - SEAT,ST HTR(KA1)
LIN: PLANT CODE-LINDEN, NEW JERSEY (CPC),LINDEN, NJ PLANT CODE(LIN)
M30: TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC,4-SPD A/TRANS(M3
N12: EXHAUST SYSTEM REAR EXIT,RR EXIT EXHAUST(N12)
N33: STEERING COLUMN,TILT TYPE,TILT STRG COL(N33)
N40: STEERING,HYDRAULIC(NON-VARIABLE),NON-VARIABLE P/S(N40)
N90: WHEEL,15X7(CAST ALUMINUM),AL WHL(N90)
NA7: EMISSION SYSTEM EUROPEAN,EUROPEAN EMISSION(NA7)
NP5: STEERING WHEEL,LEATHER WRAPPED,LEATHER WRAPPED STRG WHL(NP5)
QBG: TIRE ALL P235/70R15 WOL R/PE ST TL ALS 102S,TIRE(QBG)
RYJ: COVERING,CARGO AREA,RETRACTABLE,RETRACTABLE CARGO CVR(RYJ)
SLL: SOLD ORDERS,SOLD ORDER(SLL)
T62: LIGHTING DAYTIME RUNNING ----DELETE,T62)
T84: HEADLAMPS,RH RULE OF THE ROAD,RECTANGULAR(MARKED E),RH RULE OF R
T89: LAMP,TAIL AND STOP(EXPORT),TAIL & S/LP(T89)
T90: LAMP,SIGNALING AND MARKER(EXPORT),SIG & MKR LP(T90)
T98: STAMPING VEHICLE IDENTIFICATION NUMBER,VEH ID NUMBER STAMPING(T9
TR6: HEADLAMPS CONTROL LEVELING SYSTEM, MANUAL(EXPORT),MAN HDLP CONT
U16: TACHOMETER,ENGINE,TACH(U16)
U73: ANTENNA,FIXED,FIXED ANT(U73)
UA1: BATTERY,HEAVY DUTY,HVY DUTY BAT(UA1)
UC2: SPEEDOMETER INST, KILO & MILES, KILO ODOMETER, POSITIVE BIAS(EXP
UL2: RADIO FREQUENCY(EUROPEAN),EUROPEAN RDO FREQ(UL2)
UP8: RADIO,PROVISIONS FOR STEREO INSTRUMENTATION,STEREO RDO PROVISION
UW3: RADIO AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC SEARCH CASSETTE, D
UY7: TRAILER WIRING,7 WIRE,2 LEAD FRONT HARNESS,5 LEAD REAR HARNESS,7
V54: CARRIER,ROOF LUGGAGE(PAINTED),PAINTED RF LUGG CARR(V54)
V78: VEHICLE STATEMENT(DELETE)(EXPORT),V78)
VC5: LABEL - SHIPPING, EXCEPT US, US POSSESSIONS, OR JAPAN LABEL,SHIP
VD1: PROVISION OPTIONS,EUROPE(EXPORT),EUROPEAN PROVISIONS(VD1)
VJ3: LABEL, PLATE ECE APPROVAL & VEHICLE IDENTIFICATION,ECE APPROVAL
VJ4: LABEL, EXPORT CHILD SEAT LOCATION,LABEL CHILD SEAT LOCATION(VJ4)
VL4: LICENSE PLATE,FRONT MOUNTING PACKAGE EEC,FRT LIC PLT MTG PKG FOR
VPH: VEHICLE PREPARATION OVERSEAS DELIVERY,VEH PREP OVERSEAS DELIVERY
WX7: WIRING PROVISIONS,WRG PROVISIONS(WX7)
X88: CONVERSION CHEVROLET,CHEVROLET(X88)
XBG: TIRE FRONT P235/70R15 WOL R/PE ST TL ALS 102S,TIRE(XBG)
YBG: TIRE REAR P235/70R15 WOL R/PE ST TL ALS 102S,TIRE(YBG)
YD3: AXLE FRONT (BASE EQUIP) FOR SCHEDULING GVW PLATE,FRT AXLE(YD3)
YD5: SPRING,FRONT(BASE EQUIPMENT),FRT SPRING(YD5)
YD6: SPRING,REAR(BASE EQUIPMENT),RR SPRING(YD6)
YE3: CONVENIENCE PKG DECOR LEVEL #3, HIGH TRIM (EXPORT),HIGH TRIM LVL
ZBG: TIRE SPARE P235/70R15 WOL R/PE ST TL ALS 102S,SPARE TIRE(ZBG)
ZQ2: DRIVER CONVENIENCE PACKAGE,DRVR CONVENIENCE PKG(ZQ2)
ZQ3: DRIVER CONVENIENCE PACKAGE II(MERCHANDISING OPTION),DRVR CONVENI
ZY1: COLOR COMBINATION SOLID,SOLID PAINT COMBO(ZY1)
