1: 1: U.S. BUILT
G: G: GENERAL MOTORS
D: D: GMC INCOMPLETE
F: F: GVWR RANGE 7001-8000 BRAKE SYSTEM - HYD
K: K: CONVENTIONAL CAB GMT 400 4 X 4
1: 1: 1/2 TON
6: 6: ALL PURPOSE VEHICLE
K: K: ENG OPT - L05 DISPL(L) - 5.7 CYL - V8 FUEL SYS - TBI
5: Check digit
S: S: 1995 MODEL YEAR
J: J: JANESVILLE (T&B) WI
Код модели кузова: TK1090
Двигатель:
Коробка передач:
Модельный год: 1995
Дата производства: 15.12.1994
13D: TRIM COMBINATION CLOTH,LT GRAY,(13D)
1SP: PACKAGE-OPTION #14 OPTION PACKAGE #14 OPTION PACKAGE #14,(1SP)
1SZ: PACKAGE OPTION-,(1SZ)
41U: EXTERIOR COLOR,PRIMARY,(41U)
6GF: SPRING COMPTR SELECT FRT LH,SUSP(6GF)
7GF: SPRING COMPTR SELECT FRT RH,SUSP(7GF)
A31: WINDOW,ELECTRIC OPERATED,SIDE,ELEC SI WDO(A31)
AJ1: GLASS,DEEP TINT(REAR SIDE WINDOWS AND REAR DOOR WINDOW),DEEP TIN
APC: PROVISIONS FRT BUCKET SEATING,FRT BUCKET SEATS(APC)
AS3: SEAT,REAR UTILITY,R/SEAT(AS3)
ATZ: REAR SEAT DELETE,ATZ)
AU3: LOCK,SIDE DOOR,ELECTRIC,ELEC S/D LK(AU3)
B33: COVERING,FLOOR MATS,REAR AUXILIARY,RR AUX FLR MATS(B33)
B37: COVERING,FLOOR MATS,FRONT AND REAR AUXILIARY,FRT/RR AUX FLR MATS
B85: ORNAMENTATION,EXTERIOR,BELT REVEAL MOLDING,BELT RVL MLDG(B85)
C36: HEATER,AUXILIARY,AUX HTR,RR(C36)
C49: DEFOGGER,REAR WINDOW,ELECTRIC,ELEC RR WDO DEFG(C49)
C5Z: GVW RATING(7200 LBS),7200 LB GVWR(C5Z)
C60: AIR CONDITIONER,FRONT,MANUAL CONTROLS,A/C MAN CONT(C60)
C69: AIR CONDITIONER,RR AUX,RR AUX A/C(C69)
D48: MIRROR O/S LH & RH, REMOTE CONTROL, ELECTRIC, COLOR,ELEC R/CON P
FE9: FEDERAL EMISSION CERTIFICATION,FED EMIS(FE9)
FK2: ARM,TORSION BAR,SPRING ADJUST,LH,TORS BAR SPR ADJ ARM(FK2)
FK3: ARM,TORSION BAR,SPRING ADJUST,RH,TORS BAR SPR ADJ ARM(FK3)
G80: AXLE,REAR,POSITRACTION,LIMITED SLIP,POSITRACTION L/SLIP R/AXL(G8
GT4: AXLE,REAR,3.73 RATIO,3.73R(GT4)
JAN: PLANT CODE - JANESVILLE, WI, BOC,JANESVILLE,WI ASSEMBLY PLANT(JA
JB6: BRAKE SYSTEM,VACUUM POWER DISC,DRUM,VACUUM PWR BRK SYS(JB6)
K34: CRUISE CONTROL,AUTOMATIC,ELECTRONIC,CRCONT(K34)
K68: GENERATOR,105 AMPERE,105 AMP(K68)
KC4: COOLING SYSTEM,ENGINE OIL,ENG OIL CLG(KC4)
KNP: COOLING SYSTEM,TRANSMISSION,HEAVY DUTY,HVY DUTY TRANS CLG SYS(KN
L05: ENGINE,5.7L,TBI,5.7K(L05)
M30: TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC,4-SPD A/TRANS(M3
N33: STEERING COLUMN,TILT TYPE,TILT STRG COL(N33)
NA1: EMISSION SYSTEM,LESS THAN 8500 LB GVW,EMIS SYS(UNDER 8500 LB GVW
NA5: EMISSION SYSTEM,FEDERAL REQUIREMENTS,FEDERAL EMIS(NA5)
NP5: STEERING WHEEL,LEATHER WRAPPED,LEATHER WRAPPED STRG WHL(NP5)
NRQ: EXHAUST,CLOSE COUPLED,CLOSE COUPLED EXH(NRQ)
QBX: TIRE ALL LT245/75R16/C WOL R/PE ST TBL OOR,TIRE(QBX)
UL0: RADIO AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC SEARCH CASS, AUTO
V22: GRILLE,RADIATOR(CHROME),CHROME GRL(V22)
V54: CARRIER,ROOF LUGGAGE(PAINTED),PAINTED RF LUGG CARR(V54)
V73: VEHICLE STATEMENT - US/CANADA,US/CANADA VEHICLE STATEMENT(V73)
VK3: LICENSE PLATE,FRONT MOUNTING PACKAGE,FRT LIC PLT MTG PKG(VK3)
VK5: SEAT TEMPORARY, FOR SHIPPING,SEAT,TEMP(VK5)
VXT: LABEL INCOMPLETE VEHICLE,INCOMPLETE VEH LABEL(VXT)
XBX: TIRE FRONT LT245/75R16/C WOL R/PE ST TBL OOR (9591411),TIRE(XBX)
YBX: TIRE REAR LT245/75R16/C WOL R/PE ST TBL OOR (9591411),TIRE(YBX)
YD3: AXLE FRONT (BASE EQUIP) FOR SCHEDULING GVW PLATE,FRT AXLE(YD3)
YD6: SPRING,REAR(BASE EQUIPMENT),RR SPRING(YD6)
YE9: CONVENIENCE PKG COMFORT & DECOR LEVEL #3,COMFORT & CONVENIENCE P
YF7: RECREATION VEHICLE UPFITTER PACKAGE,RECREATION UPFITTER PKG(YF7)
Z88: GMC TRUCK,G M C(Z88)
ZBX: TIRE SPARE LT245/75R16/C WOL R/PE ST TBL OOR (9591411),SPARE TIR
ZQ2: DRIVER CONVENIENCE PACKAGE,DRVR CONVENIENCE PKG(ZQ2)
ZQ3: DRIVER CONVENIENCE PACKAGE II(MERCHANDISING OPTION),DRVR CONVENI
ZW9: BASE BODY OR CHASSIS,BASE BODY/CHAS(ZW9)
ZY1: COLOR COMBINATION SOLID,SOLID PAINT COMBO(ZY1
