1GNEK13T54J302550 посмотрите мне тоже, пржалуйста
1: 1: U.S. BUILT
G: G: GENERAL MOTORS
N: N: CHEV MPV
E: E: GVWR RANGE 6001-7000 BRAKE SYSTEM - HYD
K: K1: FULL SIZE TRUCK 4X4, 1500 (1/2 TON)
1: 3: FOUR-DOOR CAB/UTILITY (INCLUDES TRAILBLAZER,BRAVADA,
3: T: ENG OPT - LM7 DISPL(L) - 5.3 CYL - V8 FUEL SYS - MFI
T: 4: 2004 MODEL YEAR
5: Check digit
4: J: JANESVILLE WI
Код модели кузова: CK1570
Модельный год: 2004
1SN: PACKAGE - OPTION 13 OPTION PACKAGE #13 OPTION PACKAGE #13,(1SN)
62U: EXTERIOR COLOR,PRIMARY,(62U)
6XK: SPRING COMPTR SELECT FRT LH,SUSP(6XK)
7XK: COMPONENT FRT RH COMPUTER SEL SUSP (7XK),SUSP(7XK)
922: TRIM COMBINATION LEATHER, SHALE/PEWTER,(922)
92I: INTERIOR TRIM SHALE/PEWTER,(92I)
A31: WINDOW,ELECTRIC OPERATED,SIDE,ELEC SI WDO(A31)
AG1: ADJUSTER,SEAT,6-WAY POWER,DRIVER(60-40)(VAR 2),6-WAY PWR D/SEAT
AG2: ADJUSTER,SEAT,6-WAY POWER,SPLIT BENCH,PASSENGER,6-WAY PWR P/SEAT
AJ1: GLASS,DEEP TINT(REAR SIDE WINDOWS AND REAR DOOR WINDOW),DEEP TIN
AJ7: RESTRAINT SYSTEM FRT SEAT, INFLATABLE, DRIVER AND PASSENGER, FRT
AL0: SENSOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE D
AL6: RESTRAINT CARGO,CARGO RESTRAINT(AL6)
AS3: SEAT,REAR UTILITY,R/SEAT(AS3)
AT5: SEAT,RR CENTER FOLDING,RR CTR FLDG SEAT(AT5)
AU8: LOCK CONTROL REMOTE ENTRY, SPECIFIC FREQUENCY,REMOTE ENTRY LK CO
AX4: RESTRAINT SYSTEM,FRONT AND REAR SEAT,MANUAL(EUROPEAN),MAN RST SY
AXP: VIN IDENT POSITION, MULTI- PURPOSE VEHICLE,MULTI-PURPOSE VEHICLE
B30: CARPET,FLOOR AND WHEELHOUSE,FLR CPT(B30)
B58: COVERING,FLOOR MATS,FRONT AND REAR,CARPETED INSERT,CPT INS FLR M
B71: ORNAMENTATION,EXTERIOR,WHEEL OPENING MOLDING(BLACK),W/H MLDG(B71
B85: ORNAMENTATION,EXTERIOR,BELT REVEAL MOLDING,BELT RVL MLDG(B85)
BAG: PARTS PKG EXPORT,PARTS PKG(BAG)
BVE: STEPS RUNNINGBOARD, SIDE,RUNNINGBOARD SIDE STEPS(BVE)
C25: WIPER SYSTEM,REAR WINDOW,RR WDO WPR(C25)
C36: HEATER,AUXILIARY,AUX HTR,RR(C36)
C49: DEFOGGER,REAR WINDOW,ELECTRIC,ELEC RR WDO DEFG(C49)
C69: AIR CONDITIONER,RR AUX,RR AUX A/C(C69)
CJ2: HVAC SYSTEM AIR CONDITIONER FRT, AUTO TEMP CONT, AUX TEMP CONT,A
CZ3: COUNTRY RUSSIA(EXPORT),RUSSIA(CZ3)
D55: CONSOLE,FRONT COMPARTMENT FLOOR,F/CMPT FLR CNSL(D55)
DH6: MIRROR,INSIDE,VISOR VANITY,RH AND LH(ILLUM),ILLUM S/S MIR(DH6)
DT4: ASH RECEPTACLE AND CIGARETTE LIGHTER,ASH TRAY & C/LTR(DT4)
EVA: TEST DVT, EVAP EMISSION REQUIREMENT,EVAP EMISSIONS REQUIRED(EVA)
EXP: EXPORT - I.E.S. EXPORT I.E.S.,EXPORT-SPECIFIC MARKET AREA EQUIPM
FK2: ARM,TORSION BAR,SPRING ADJUST,LH,TORS BAR SPR ADJ ARM(FK2)
FK3: ARM,TORSION BAR,SPRING ADJUST,RH,TORS BAR SPR ADJ ARM(FK3)
G80: AXLE,REAR,POSITRACTION,LIMITED SLIP,POSITRACTION L/SLIP R/AXL(G8
GT4: AXLE,REAR,3.73 RATIO,3.73R(GT4)
J81: INDICATOR SWITCH, EXPORT,IND SWITCH (EXPORT)(J81)
JAN: PLANT CODE - JANESVILLE, WI, BOC,JANESVILLE,WI ASSEMBLY PLANT(JA
JE1: BRAKE SYSTEM(EUROPE)(EXPORT),EUROPEAN BRK(JE1)(EXPORT)
JF4: PEDALS ADJUSTABLE, POWER,PWR ADJ PEDALS(JF4)
JH2: BRAKE HYD POWER, DISC/DISC, 7, 200 LBS,7200# PWR BRAKES(JH2)
K34: CRUISE CONTROL,AUTOMATIC,ELECTRONIC,CRCONT(K34)
K47: AIR CLEANER HIGH CAPACITY,HI CAPACITY A/CL(K47)
KG3: GENERATOR 145 AMP,145 AMP(KG3)
KNP: COOLING SYSTEM,TRANSMISSION,HEAVY DUTY,HVY DUTY TRANS CLG SYS(KN
KUP: THROTTLE CONTROL VARIABLE SPEED (ELECTRONIC),ELECTRONIC THROTTLE
LM7: ENGINE GAS, 8 CYL, 5.3L, MFI,5.3T(LM7)
M30: TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC,4-SPD A/TRANS(M3
MAE: MARKETING AREA EUROPE(EXPORT),EUROPE(MAE)
N12: EXHAUST SYSTEM REAR EXIT,RR EXIT EXHAUST(N12)
NP5: STEERING WHEEL,LEATHER WRAPPED,LEATHER WRAPPED STRG WHL(NP5)
NP7: STEERING COLUMN(EXPORT),STRG COL(NP7)(EXPORT)
NP8: TRANSFER CASE ACTIVE, TWO SPEED, PUSH BUTTON CONTROL,TRANSFER CA
NT3: EMISSION SYSTEM EEC 00,EEC 00 EMIS SYS(NT3)
NZZ: PACKAGE,OFF ROAD SKID PLATE,SPORT,SKID PLT PKG(NZZ)
PF9: WHEEL 16 X 7, ALUMINUM CAST,CAST ALUM WHL(PF9)
QMJ: TIRE ALL P265/70R16 BW R/PE ST TL AL2 111S,TIRE(QMJ)
SAF: LOCK SPARE TIRE, HOIST SHAFT,SPARE TIRE LOCK HOIST SHF(SAF)
SLL: SOLD ORDERS,SOLD ORDER(SLL)
SLT: EQUIPMENT CHEVROLET 'LT' OR GMC 'SLT' SALES PKG,'LT'/'SLT' EQUIP
T2H: ORNAMENTATION,UNIQUE REQUIREMENTS(EXPORT),ORNAMENTATION REQUIREM
T2J: ORNAMENTATION,INTERIOR,EXPORT UNIQUE REQUIREMENTS(EXPORT),INTR O
T62: LIGHTING DAYTIME RUNNING ----DELETE,T62)
T79: LAMPS,REAR FOG(EXPORT),RR FOG LP(T79)
T84: HEADLAMPS,RH RULE OF THE ROAD,RECTANGULAR(MARKED E),RH RULE OF R
T89: LAMP,TAIL AND STOP(EXPORT),TAIL & S/LP(T89)
T96: LAMP,FRONT FOG,FRT FOG LP(T96)
T98: STAMPING VEHICLE IDENTIFICATION NUMBER,VEH ID NUMBER STAMPING(T9
TR2: LAMP,TURN SIGNAL,ENLARGED(EXPORT),ENLARGED T/SIG LP(TR2)
TR6: HEADLAMPS CONTROL LEVELING SYSTEM, MANUAL(EXPORT),MAN HDLP CONT
UC2: SPEEDOMETER INST, KILO & MILES, KILO ODOMETER, POSITIVE BIAS(EXP
UC6: RADIO AM/FM STEREO, SEEK/SCAN, RDS, MULTIPLE COMPACT DISC, AUTO
UK3: ELECTRONIC SYSTEM,ACCESSORY CONTROL,ELEK ACSRY CONT SYS(UK3)
UK6: RADIO CONTROL REAR SEAT & EARPHONE JACKS,RR ST AUDIO(UK6)
UL2: RADIO FREQUENCY(EUROPEAN),EUROPEAN RDO FREQ(UL2)
V22: GRILLE,RADIATOR(CHROME),CHROME GRL(V22)
V54: CARRIER,ROOF LUGGAGE(PAINTED),PAINTED RF LUGG CARR(V54)
V76: HOOK,FRONT TOW,FRT TOW HOOK(V76)
V78: VEHICLE STATEMENT(DELETE)(EXPORT),V78)
V92: TRAILER PROVISIONS,TRLR PROVISIONS(V92)
VB3: BUMPER,REAR STEP,INCLUDES IMPACT STRIP(CHROME),CHROME STEP BPR(V
VC5: LABEL - SHIPPING, EXCEPT US, US POSSESSIONS, OR JAPAN LABEL,SHIP
VCG: PROVISIONS INTERNATIONAL SWITCH/CONTROL SYMBOLS,INTL SWI CTL SYM
VD1: PROVISION OPTIONS,EUROPE(EXPORT),EUROPEAN PROVISIONS(VD1)
VG3: STRIP,FRONT BUMPER IMPACT,FRT BPR IMP STR(VG3)
VJ3: LABEL, PLATE ECE APPROVAL & VEHICLE IDENTIFICATION,ECE APPROVAL
VPH: VEHICLE PREPARATION OVERSEAS DELIVERY,VEH PREP OVERSEAS DELIVERY
VZ2: CALIBRATION- SPEEDOMETER A,SPEEDO CALIBRATION(VZ2)
X88: CONVERSION CHEVROLET,CHEVROLET(X88)
XMJ: TIRE FRONT P265/70R16 BW R/PE ST TL AL2 111S,TIRE(XMJ)
YD3: AXLE FRONT (BASE EQUIP) FOR SCHEDULING GVW PLATE,FRT AXLE(YD3)
YD6: SPRING,REAR(BASE EQUIPMENT),RR SPRING(YD6)
YE9: CONVENIENCE PKG COMFORT & DECOR LEVEL #3,COMFORT & CONVENIENCE P
YMJ: TIRE SPARE P265/70R16 BW R/PE ST TL AL2 111S,TIRE(YMJ)
ZMJ: TIRE REAR P265/70R16 BW R/PE ST TL AL2 111S,TIRE(ZMJ)
ZY1: COLOR COMBINATION SOLID,SOLID PAINT COMBO(ZY1)
