SERVICE BRAKE BOOSTER MessageThe SERVICE BRAKE BOOSTER message will be displayed when the supplemental brake assist signal circuit is toggled at 1.0 Hz with a 50 percent duty cycle. This message is also displayed if the Instrument Panel Cluster (IPC) does not see an alive and well signal at key on. When this message is displayed it indicates a problem with the SBA and should be serviced or replaced.
Сообщение SERVICE Усилитель тормозного привода будет отображаться, когда дополнительный сигнал торможениясхема переключается при 1,0 Гц с рабочим циклом 50 процентов. Это сообщение также отображается, если приборПанель Cluster (IPC) не видит живым и здоровым сигнал на ключ на. Когда это сообщение отображается егоуказывает на проблему с СБА и должны обслуживаться или заменены.
SERVICE BRAKE BOOSTER INDICATOR ON20031. Did you review the brake warning system description and operation and the hydraulic brake assist system description and operation, then perform the necessary inspections? If so, go to next step. Ifnot, see HYDRAULIC BRAKE SYSTEMunder GENERAL DIAGNOSIS under TROUBLE SHOOTING.2. Start the vehicle. Is the REDUCED BRAKE POWER message displayed for one minute before the SERVICE BRAKE BOOSTER message is displayed? If yes, go to next step. If no, go to step 4. 3. Perform BRAKE ASSIST SYSTEM DIAGNOSISunder TROUBLE SHOOTING. Did you find and correct the condition? If yes, go to step 12. If no, go to step 11.4. Disconnect the supplemental brake assist pump motor connector. See Fig. 36. Test the ignition 1 circuit (Pink wire) between supplemental brake assist pump motor connector and SBA (15-amp) fuse in underhood junction block for an open or a short to ground. Did you find and correct the condition? If yes, go to step 12. If no, go to next step. 5. Check Black and Black/White wires between supplemental brake assist pump motor connector and ground for an open. Did you find and correct the condition? If yes, go to step 12. If no, go to next step. 6. Test the engine on signal circuit (Dark Blue at generator; Black/White at supplemental brake assist pump motor) between supplemental brake assist pump motor connector and SBA (15-amp) fuse in underhood junction block for an open or a short to ground. Did you find and correct the condition? If yes, go to step 12. If no, go to next step. 7. Test the vehicle speed signal circuit (Dark Green/White wire) between supplemental brake assist pump motor connector and instrument cluster for an open. Did you find and correct the condition? If yes, go to step 12. If no, go to next step. 8. Test the supplemental brake assist signal circuit (Dark Blue wire) between supplemental brake assistpump motor connector and instrument cluster for an open or a short to voltage. Did you find and correct the condition? If yes, go to step 12. If no, go to next step. 9. Reconnect the supplement brake assist pump motor connector. Disconnect the instrument panel cluster connector. Connect a DVOM from battery voltage to the supplemental brake assist signal circuit (Dark Blue wire). Turn the ignition to the Run position while observing the DVOM. Did the DVOM flash battery voltage? If yes, go to step 11. If no, go to next step. 10. Replace the supplement brake assist pump motor. See SUPPLEMENT BRAKE ASSIST PUMP MOTORunder REMOVAL & INSTALLATION. After repair, go to step 12.11. Replace instrument panel cluster. See INSTRUMENT PANEL CLUSTER under REMOVAL & INSTALLATION in appropriate ANALOG INSTRUMENT PANELS article in ACCESSORIES & EQUIPMENT. After repair, go to next step.12. Start the engine. Does the SERVICE BRAKE BOOSTER message stay on? If yes, go to step 2. If no, system is okay.
