Надеюсь переведете сами.
1997 Chevy Truck S10/T10 Blazer 4WD V6-4.3L VIN W Copyright © 2011, ALLDATA 10.50PE Page 1
Engine: Service and Repair
Oil Pan Installation
Important: Apply the sealer, GM P/N 12346192 or equivalent 25 mm (1.0 in) in either direction of the radius cavity of the junctions.
http://roadster.users.photofile.ru/photo/roadster/3112602/210376497.jpg1. Apply a small amount of sealer, GM P/N 12346192 or equivalent, 10 mm (0.393 in) wide and 20 mm (0.787 in) long to the engine front cover
to engine block junction.
http://roadster.users.photofile.ru/photo/roadster/3112602/210376498.jpg2. Apply a small amount of sealer, GM P/N 12346192 or equivalent, 25 mm (1.0 in) long to the crankshaft rear oil seal housing to engine block
junction.
Important: Always install a new oil pan gasket.
3. Install the oil pan gasket.
4. Install the oil pan against to engine block.
5. Slide oil pan back against straight edge using a J 34673 or equivalent.
Important: Use a feeler gauge to check the clearance between the three oil pan-to-transmission bell housing contact points. If clearance
exceeds 0.254 mm (0.010 in) at any of the three points repeat steps until the clearance is within specification.
6. Install oil pan bolts and nuts. Do not tighten.
Notice: If the clearance is more than 0.254 mm (0.010 in), powertrain durability may be impacted.
7. Install the bolts and nut using the following sequence:
Tighten
7.1.Tighten the bolts to 25 Nm (18 lb ft).
7.2.Tighten the nuts to 25 Nm (18 lb ft).
8. Measure the clearance again between the three oil pan-to-transmission bell housing contact points to verify proper alignment.
9. Install the oil filter gasket.
10. Oil filter adapter 0-ring seal, if equipped.
11. Oil filter adapter bolts.
Tighten
Tighten the bolts to 20 Nm (15 lb ft).
12. Inspect oil filter adapter bypass valve and spring for operation and cracks. If bypass valve looks damaged in any way replace the oil filter
adapter assembly.
13. Lubricate new oil filter seal with clean engine oil.
14. Install a new oil filter.
