На шильде где VIN в бардочке скорее всего, должен быть один из этих кодов UQ7 или Y91
Nav part numbers:
Newest revision LUX TNR-------15800001
Second Revision LUX TNR-------15230099
First Revision LUX TNR---------10377531
Newest revision non-lux TNR-----15800000
second Revision non-lux TNR---10379287
First Revision non-lux TNR-------10377287
Alt. Revision non-lux TNR---------15120706
Newest Revision LUX INR--------15204335
First Revision LUX INR------------15204334
Newest Revision non-lux INR----15108241
NON-BOSE TNR (trucks with UQ3/UQ5 non-Bose audio)-----15811289
Lux Amplifier numbers: (all are identical in function, they just have different part numbers)
2003-early 2004 Escalade amp--15199992
2005 Escalade amp-----------------15114445
2003-2005 Denali amp-------------15114454
2003 Hummer H2 amp-------------xxxxx044 (I forget the first numbers)
Early 2004 Hummer H2 amp-----15191601
(unknown application) amp-------15112662
(unknown application) amp-------15199884
I have this amp on my list as a "bad amp" but Im not sure why-----------15054675
it is confirmed as working with the nav unit; its the amp im running in my truck
GPS antenna:
First revision antenna--------------15207447
Latest revision antenna------------15135178
“AudioPilot” Noise Compensation Microphone:
Noise compensation mic----------25705367
Wiring connector on mic----------12052833
Mating connector for mic----------12085481
Denali/Escalade style CD changer and assoc. parts
6-disc slot load CD changer------15055250
Alternate part # CD changer------15122617
Alternate part # CD changer------15207055
CD changer wiring harness-------15312903
