он открутить не мог..
кто знает как разобрать рулевую колонку на блейзере квадратном?
В общем вот что нам говорит Чилтон:
Steering Column
REMOVAL & INSTALLATION
1. Disconnect the negative battery cable.
2. Matchmark the relationship of the upper pot joint to the steering shaft, then remove the nut/bolt and separate
the joint from the shaft.
3. If equipped with a column mounted shifter, disconnect the transmission control linkage from the column shift
tube levers.
4. If equipped, remove the lower steering column trim panel.
5. If applicable, disconnect the shift indicator cable from the shift bowl.
6. If necessary, remove the steering wheel.
7. Remove the bolts from the column floor/toe plate.
8. Remove the column support bracket-to-instrument panel retainers, then carefully lower the column for
access to the wiring.
9. Disengage all of the electrical connectors from the steering column assembly.
Once the steering column has been removed from the vehicle, be careful not to drop it (especially on its end), lean on
it or damage it in any way; the column is very susceptible to damage.
10. Remove the column from the vehicle. Rotate the column so the shift lever clears the cowl opening.
